  #164 (permalink)
Old 11-26-2009, 02:32 AM
Double Venom's Avatar
Double Venom Double Venom is offline
Ray,
Here comes another 2-cents for you. Actual testing by TRC (Honda's test track in Marysville, Oh.), actually showed (Time wise among other tests) that the front sway bar that CR's used is WAY to heavy for this car! Times, dropped and improved significantly WITH OUT the CR's front sway bar.
CR's used what was available from OEM for the front say bar in the late '70's. A Ford BRONCO - 4-wheel drive!"
Ride and steering is greatly improved by removing and NOT using the supplied sway bar!*
*Note - This post is NOT intended or should be taken as "A" front sway bar is not needed on a CR's Cobra! Make your own, SPEEDWAY sells all kinds of parts to make a bar that will work. Usually, even with a Big Block a 1/2 diameter bar will work just fine, but certainly not a bar that is over 5/8's in diameter!
DV
