DV: That is more like 10 cents worth, and I was really wondering if this thing was over kill. While preparing that giant piece I was having second thoughts.
I think I have an orginal mustang II front sway bar. or a couple others thrown in the attic. I will check out summits as well.
And while I have your attention, I notice I have this cover that will fit over the large recess in the firewall to cover up the wiring harness where it come thru the firewall. Or is this intended to be a cover if a person does not use that connection. I was figuring to go ahead and use the square hole the previous owner cut out and prefit the harness into. tHen I thought about modifying this cover to place over it after the wiring was installed. Or I though about just leaving it off. I also thought about glassing it in and routing the wires much lower in the firewall so as to be more hidden.
Your 2-cents please. Will the sway bar go on and off with the radiator still in the car. Seems to me it might not make the turns to get in and out.
