Old 11-26-2009, 12:44 PM
sunman's Avatar
sunman sunman is offline
DV
I was electronic tech for years. Maybe this will help. Use voltmeter to check voltage while cranking at ignition box. If good check output to dist. If bad work backwards to cranking power source. In electronics its just like everything else, divide and conquer. My guess is bad wire in cranking power circuit.
Thank god you have a simple problem and your not replacing Q panels and floors on classic Mustangs.
Sunman
