Thread: turkey pans
Old 11-28-2009, 10:58 AM
Gunner's Avatar
Gunner Gunner is offline
Cobra Make, Engine: ERA 707, 446ci FE
Originally Posted by wrench87 View Post
when you run a turkey pan i assume there is a gasket then the pan then another gasket then carb? i already have the cobra oval air cleaner assbly with the larger k&n filter so i am unsure wich one to run. thanks for the info.
Yes, you put a gasket under the pan and under the carb.
I got my car with a turkey pan and small air cleaner. Because I have to fit it with a PCV and closed breather to pass the California exam, and because I wanted better breathing for daily driving, I fit it with a long oval that has room on the underside to attach the breather hose. Both look good and fit well. I will be putting the pan and S&H cleaner back on for show, but the long oval has twice the breathing area of the little cleaner. Some folks have done calculations and shown that a K&N filter in the small air cleaner should provide enough flow, but a K&N in the long oval leaves no question about it.
It's your choice. Both look good and even the long oval is reasonably correct.
= Si Opus Quadratum vis, angulos praecidere noli. =
