Thread: Tilt Front
Old 11-28-2009, 08:27 PM
Stinson Pilot's Avatar
Stinson Pilot Stinson Pilot is offline
Cobra Make, Engine: FFR MKII #3133 3:27 Pin Width IRS, Carb'd Explorer 302 w/GT40P Heads, 3550 Mid Shift, Power Brake Mod, 15" Torque Thrust D's
Default Tilt Front
Thought you guys might like to see this. I've found some interest in it in my searches. This is on a FFR, but could probably be done on others.
It's coming along.
I made the initial cut with a very thin cutoff wheel and cut the two corners with a jig saw. Layout for the cuts wasn't too hard. Did as much measuring as I could and stood back and eyeballed it till it looked right.
I'll use prop rods to hold it open. They'll clip onto the sides of the upper 3/4" tubes when the hood is closed.
I used structural epoxy for all bonding.
I haven't settled just yet on the latch. I've got several ideas I'm kicking around.
Open:
I made the hinges from 1/4" aluminum and bolted them through the 3/4" tubes with 3/16" bolts. The other half of the hinge was some airplane parts that I had laying around, but could be made from a couple angle aluminum pieces just as easy. I bonded them to the body with HSRF. Make sure you scuff up things real good with 80 grit before bonding. The hinge bolts are 1/4" bolts.
I wasn't totally comfortable with just bonding these hinges, so I put two 3/16" bolts through the body and will use Rage Gold to blend them into the body on the front side.
I bonded 1/8"x3/4" aluminum angles to the cut areas. Drilled and tapped for 3/16" bolts ground down to a point. This also strengthens this fiberglass piece.
Doug
