Old 11-30-2009, 01:43 PM
Tom Kirkham Tom Kirkham is offline
CC Member / Sponsor
Originally Posted by trularin View Post
Great Tip!!!
If you use the 8-32 screws, you can have a wider range of sizes.
I would recommend a small amount of loctite blue if the set screws are easy to turn.
Thanks for the tip!
Typically we do not tap the entire length of the hole. This way we can bottom out the jet and Locktite is not needed. However if you tap all the way through you will need Locktite to keep the jet from falling through...
Cubic Performance
HiTech Legends
https:HiTechLegends.com
Evolve Lubricants
https://evolvelube.com/
