Old 12-01-2009, 07:19 AM
FWB's Avatar
FWB FWB is offline
Originally Posted by Three Peaks View Post
Since the original style wiper switch no longer seems to be available, has anyone found a replacement switch that will work as the original?
I looked at some (in a catalog) made by Cole Hersee that may work, but I can't tell for sure. Any clues what to look for? They have several available, 4 tabs, 5 tabs, 7 tabs for the two speed without dymanic braking and no push-to- wash.
Of course, if anyone has a line on the original style switch I'd be up for that also...
Here are the switches I've been looking at- any idea which one might work with the two speed MG wiper motor?
http://www.elecdirect.com/catalog/95...37e08a4e5.aspx
Thanks,
Bob
bob, i just went through this last year with my kellison. ultimately you will need to know if the MG motor has a park circuit inside of it or not. the cole herse line has both switches with or without dynamic park. dynamic park means the motor has a park circuit inside of it. get a MG wiring diagram and this will lead you to how the motor is wired. most vehicles including british leyland use dynamic park. the link you have in your post is fine but go to cole herses web site and look at their catolog it is a bit more comprehensive........good luck,
fred
