Old 12-03-2009, 11:21 AM
undy's Avatar
undy undy is offline
Originally Posted by wrench87 View Post
undy, is it possible to install all the studs and drop the intake on?, or do you have to install them afterwards?. also do you remember the lengths of the studs?. i am using studs for my valve covers and oil pan windage tray. it would be nice to find the studs that you can use a allen wrench on to tighten.
As Cobrabill said the intake bolts are splayed. You can't remove or install the intake with the studs in place. Once you set the intake you just simply screw the studs in, no big thing. Unfortunately there's no one that makes intake studs for an FE so allen headed studs aren't there. The screw drive slot works fine anyway. I got a 3' piece of hardened 304 stainless steel all-thread (12 bucks) and spent 30 minutes making the kit. They'll pull down 35 ftlbs dead solid with no stud or thread flex. It's a great mod!!
dave
Too many toys?? never!
