Old 12-04-2009, 06:02 AM
madmaxx madmaxx is offline
Loose the duraspark go with aftermarket MSD or equivalent. Duraspark works great when it works, put they dont seam to last long in spf's and if yours melted there is another issue. So run all new wiring from scratch when you install your aftermarket ignition and you will be done.
My very late chassis has hydraulic clutch and slave works perfect with perfect pedal stroke. You can buy the slave and bracket from cincinatti performance and either reuse the clutch master cylinder or buy a new one, cant cost much.
