Thread: Build update
  #28 (permalink)
Old 12-04-2009, 01:29 PM
sambo's Avatar
sambo sambo is offline
Thought I would share an idea for fellow Harrison builders, with particular relevance to those using Sideshow's LS engine loom conversion.
The photos below show the passenger footwell with two aluminium panels mounted with nutserts for easy removal. The top panel holds the Holden ECU and the bottom section is a swing-down panel where I've mounted the engine loom fuses and relays. It makes good use of the available space and is sturdy enough to mount upholstery at a later date.
If anyone in Melbourne has a right-angle drill I could borrow for a few hours, I'd love to hide that exposed hinge as I have for the other one. Clearance is about 100mm at the lowest point.
