Old 12-04-2009, 07:08 PM
*13*'s Avatar
*13* *13* is offline
Originally Posted by zrayr View Post
what linkage did you end up using ?
Z. Ray
This is essentially how you want to be set up. Pivoting from the center point to get the carb banks to open at the same ratio through the range. Some of the setups you can buy have a link from one bank to the other which doesn't even come close to opening the banks at the same rate. If your carbs are all facing the same way, ie. fuel lines all connecting on the driver side of all the carbs, then you can push the banks from one to the next. Otherwise you need to figure out a linkage that works both banks in unison like this. I'll try to find another linkage setup I've seen & Post it....If I can find it...
THis is the bad linkage setup-->
ERA FIA 2088
