Old 12-05-2009, 01:05 PM
lal Naja's Avatar
lal Naja lal Naja is offline
Cobra Make, Engine: Butler Cobra. 350 Chevy Engine, blueprinted, heads cc'd, ported, polished, manifolds matched, big valves, 1.6 roller rockers, TB Injected, mild cam, MSD crank trigger electronic ignition. TKO-600 transmission. XKE Jaguar rear. IFS by Fast Cars
It's a 3-wire switch and I think it would have been okay with the original sealed-beam headlights. I have upgraded to 100/90 watt halogens, so I'm going to change the headlight wires in my harness to thicker gauge wires and If I'm going to do that, adding a relay would be a no brainer.
Your suggestion for a vent for cooling is probably a good idea too. I think I will cut some slots in the top & bottom of the headlight metal buckets to allow some air circulation. Normal convection will allow air to enter from slots in the bottom to flow out from the top.
Thanks,
Arthur
