Old 12-05-2009, 06:01 PM
Cobra 29 Cobra 29 is offline
Cobra Make, Engine: ERA 427SC FMS 351W
Default Why not use the Mocal Oil Temp Sandwich Adapter?
I have existing oil lines to / from a oil cooler too without a themostat. I need to install a themostat or disconnect the oil cooler to build greater oil temp. Blocking the oil cooler helps build heat but you still have the drag / pumping losses of all the oil lines and cooler.
For a car with existing lines and a cooler, it seems easier to use the Mocal sandwich adapter that contains a oil themostat. This avoids another mount to the frame and more oil line connections. Maybe this adapter and shorty oil filter will not fit between your frame and original oil filter mount on the block??
SuperHart uses one and he reports it works fine. Any other experences with this adapter?
