Old 12-06-2009, 08:13 AM
mdross1's Avatar
mdross1 mdross1 is offline
As you move your spring collar up, your car will go up higher as well. But it's not a 1 to 1 ratio. Meaning if you want to move your car up an inch you will move the spring collar up by less than an inch -- maybe three-quarters, maybe two-thirds, but you get the idea. That's on my car, though. Your car's spring to results ratio will be different, but still similar.
EDIT -- After getting your ride height perfect you should do final adjustments with your car on scales. Getting your corner weights just right makes a tremendous difference in the way the car drives.
Exactly,what should be done, have the car scaled.It will never be right if you don't.Ask me how I know?
