Old 12-06-2009, 08:43 PM
elmariachi elmariachi is offline
Two four barrels will give you more horsepower, but you lose the benefit of the center hung floats.
There are no curves in south Texas so I can handle that.
You also lose the beautiful Turkey Pan.
Didn't have one yet anyway.
Originally Posted by vector1 View Post
peak tq was 474 at 4500, peak hp was 467 at 5500. this is conservative.
I have a fresh 427 SO, 4.250 bore, 9.8:1 compression, Comp 294S flat tappet (.605 lift), a set of new-out-of-the-box unworked medium riser heads, Erson roller rockers, Le Mans rotating assembly, Sidewinder intake and a 750 Mighty Demon and it made 451HP and 482 ft lbs of torque at the flywheel on a bonafide NHRA engine dyno. Plug that into your eap and tell me what it says. The software will claim much more.
