Old 12-06-2009, 10:06 PM
markha markha is offline
OK. I pulled them tonight and realized that I did a bit of a rookie move. These are all Italian IDA that I bought used from various places. In rebuilding them, I did not keep the butterflys with the same carbs. No big deal... right? Well tonight I realized that some of the butterflys had been drilled with an idle correction hole and others had not. So when I reassembled them, you guessed it, I wound up with some carbs with one butterfly that was drilled and one that was not in the same carb.
So now.... do you guys run these holes? These are small (about 1mm) holes in the butterflys at the opposite site from the progression holes. I have enough butterflys that have the holes to make them all the same, but with the idle so high, I am tempted to solders these holes up.
Thanks,
Mark
