Old 12-07-2009, 08:26 AM
Chaplain's Avatar
Chaplain Chaplain is offline
Cobra Make, Engine: Everett-Morrison, 429CI
Do you have the correct shift lever on the reverse cam and shaft? Depending on the sheft lever used the hole that locates the shift arm would swing through a longer arc causing the gear to not fully engage/disengage.
