Old 12-07-2009, 08:47 AM
capteddie's Avatar
capteddie capteddie is offline
Cobra Make, Engine: CRII 351W/408 Stroker
Send a message via AIM to capteddie
Winter blows! !
Well with the temps dropping faster than a rock off the Sears tower and my heater for the garage not getting hooked up till next weekend. I tucked the car away. Was suppose to get the transmission fixed and the engine dialed in. Looks like that'll wait till spring. I think once the heater gets installed in the garage. I'm going to pull the drivers seat and see if I can make the Kirkey I originally wanted to use fit.
http://www.kirkeyracing.com/index.ph...code=Series41V
Even though it would be less comfortable. I think it would give me some extra leg room. We'll see
I ran the car pretty much empty and then mixed a couple gallons of gas with some stabilizer and put it in the tank. I then ran the car for a minute or 2, to get the fuel mixture in the lines and carb. I hooked my battery tender up and put the cover on the car. Should I need to do anything else for the winter, storage wise?
"the other ed"
