Old 12-07-2009, 12:09 PM
MaSnaka's Avatar
MaSnaka MaSnaka is offline
My kit came with two sets of "L" clips. I used the longer clip and it scewed into three mounting screws under the headlight ring. I replaced the trim ring. Then snapped the grid onto the clips (3 clips each side) and adjusted (bent) the clips to hold it snug and centered. Then I took a pair of needle nose pliers and just rolled back the part of the clip that extended past the installed grid and pinched it tight. No way to lose a grid and you won't loose skin if you brush against those exposed ends. The grids sit about 1/2" in front of the glass. Looks clean.
John
