Old 12-07-2009, 02:02 PM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Originally Posted by Ibr8k4vetts View Post
Anthony,
How well dose that cam idle or dose it?
It idles fine when warm, a little rough when cold. The problem is that valve lash changes with temperature. Since it is an iron block, the valve lash doesn't tighten up much when cold (about 0.006"), but if it were an all aluminum engine, cold starting would be more of a problem, around 50 degrees and less.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
