Old 12-08-2009, 09:28 AM
Gunner's Avatar
Gunner Gunner is offline
Cobra Make, Engine: ERA 707, 446ci FE
Originally Posted by STL Mark View Post
I have a dual plane inkake and a Mighty Deamon Carb. And a Small Air Cleaner. I tried and failed to make fit one of those big oval Cobra air cleaners.
I have an FE with a Demon that would not fit a long oval air cleaner until I made fairly extensive mods to the base plate. I ground the carb ring down to nothing in the rear, about half original height in the front, and tapered. This meant I had to drill a hole to let the rear carb float screw pass through the baseplate. To seal the gap, I epoxied in a soft bulls-eye gasket from a generic brake-fluid lid replacement. Dropped the rear of the AC about an inch, from a half inch interference to a half inch clearance.
= Si Opus Quadratum vis, angulos praecidere noli. =
