Old 12-08-2009, 01:37 PM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
Default Using Superlite Caliper
Hey All,
Quick question.
I am using Superlite Wilwood Calipers and was bleeding my brakes using the pressure system. This is a pump that I pump pressure through the brake canisters and open the bleed screws to release the air. I disconnected the brake pedal (using 2 master cylinders).
With the Superlites I get very slow fluid when released.
The rear with the dynalites are more responsonsive.
All the aire is out and the brakes feel fine. However this is just making me think why this is happening.
I have also tried with the pumping of the pedal but the superlites still flow the fluid very slow.
I disconnected the system to see if there is a blockage and everything systems fine.
Your thoughts?
