Old 12-11-2009, 10:02 AM
kitcarbp's Avatar
kitcarbp kitcarbp is offline
Cobra Make, Engine: West Coast, 460 Ford Racing Crate w/ TREMEC TKO 600
The only info I have is the input shaft hardness must be sufficient to be able to use a modern needle bearing type roller bearing which I am using. The TKO input shafts are hardened and should not care either way, but I have a noise I am trying to pinpoint.
"...some assembly required, ages 8 and up...... well that took longer than expected......
