Old 12-11-2009, 11:52 AM
kitcarbp's Avatar
kitcarbp kitcarbp is offline
Cobra Make, Engine: West Coast, 460 Ford Racing Crate w/ TREMEC TKO 600
Default Block pLate
Steve, Your picture shows no block plate being used ???. This is the plate that goes between the engine and trans and is also needed for correct starter alignment to ring gear. If you dont have it fitted, this would move the trans (input shaft and splines) about 0.070-.090 ". I cant tell from your photos if you have it fitted. If its fitted and you have the right one, ignore above.
"...some assembly required, ages 8 and up...... well that took longer than expected......
