Old 12-11-2009, 02:49 PM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Numbers/rlosses may be dependent on dyno's used, so it may be hard to compare different cars tested on different dyno's.
An IRS will use more HP than a solid rear axle.
You usually chassis dyno a car in a 1:1 gear, the gear to have the least hp loss, so that would be 4th gear on a toploader, and 4th gear in a tremec. Loss, I guess, would be about the same, maybe giving the advantage to the tremec since it runs a thinner tranny fluid.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
