Old 12-15-2009, 03:00 PM
cdnus cdnus is offline
Cobra Make, Engine: 408w 500 h.p. 550 ft.lbs
Doug
With a manual choke you should depress the throttle 1/4 then pull the choke on while the peddle is depressed, then release the peddle. This will engage the fast idle cam allowing the engine to fast idle once started, (do not touch the peddle once the choke is engaged) when it starts you can slowly push the choke in as required to keep the engine running clean.
If the engine will not fast idle once started you may have to adjust the screw for that on the fast idle cam to increase the speed.
Once the engine is warmed up & can idle on its own push the choke all the way in & tap the gas peddle to release the fast idle cam.
You should be good to go.
You will soon learn the small differences required for your car, but this is the general method used.
Craig
