Old 12-16-2009, 06:15 PM
zrayr's Avatar
zrayr zrayr is offline
Cobra Make, Engine: Fords
Originally Posted by Tom Kirkham View Post
Every carb is different. You will need a wide band O2 sensor to get to the right size hole. It is safer to start with bigger. A quick way to see if this is what you need to do is insert a piece of wire in the PVCR to make the effective hole smaller.
In the stock Holley metering block I am not aware of any inserts in the PVCR. Of course in the idle circuit their typically is a brass insert.
Tom,
can you envision just using the air bleed jets instead of a brass set screw ? Is there enough material in the metering block to set the bleed jets in deep enough to clear the power valve ?
Z. Ray
'65 K code Mustang
'66 Galaxie 500
