Old 12-16-2009, 06:22 PM
blykins blykins is offline
Yes, advance the cam to a 106° ICL. (If it's a 110 LSA...which we really don't know. You may need to put a degree wheel on it and check out the actual specs.)
You don't have to pull the head to check piston/valve clearances. Just pull an intake and an exhaust valve spring off, replace them with a checking spring, then use a dial indicator to see how far you can push the valve down until it touches. You will also need a degree wheel for this as you need to check the clearances where the valves would be the closest. For the intake valve, it's usually from TDC to 10° ATDC, where the intake valve is trying to chase the piston down on the intake stroke. The exhaust valve is usually closest 10° BTDC to TDC, where the piston is chasing the exhaust valve back down to the seat.
The only idle quality that you'll see a change in is how clean it idles, how well it takes gas down low, etc. Overlap doesn't change when you advance/retard cam timing.
The Voodoo cams are nice. Usually tighter LSA's narrow the range a little. When it comes time to go through it, you can give me or one of the other builders a call and we can help you pick a cam that will meet your needs perfectly.
If you do plan to go through it later on, I'd probably just drive it and enjoy it for now.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
