Old 12-20-2009, 05:52 AM
Woodz428's Avatar
Woodz428 Woodz428 is offline
Cobra Make, Engine: Coupe,Blue w/white stripes SB; Roadster, Blue w/white stripes BB w/2-4s; SPF installer/Hot Rod-Custom Car builder
Originally Posted by portmax View Post
i have since upgraded to edelbrock performer rpm cam and intake 1 inch spacer and 850 holly w 30 cfm stub stack, jacobs ign. and 3 inch id 5 inch od mufflers and is it loud! needs jet work , anyone know a rule of thumb on jet size diff w open headers , i seem to have a little carb popping at 2500 rpm
As mentioned, make sure everything else is correct before you start playing with jetting. You could be experiencing a timing issue, as mentioned or too much preload on the lifters. If you retained the stock rocker studs and they are positive stop, you couldn't set preload, unless it happened to be correct you would be on one side or the other. When machine work is done( head/block decking) that changes the dimensions between the cam and heads and needs some adjustment. If it is too tight it can create popping through the carb at various rpms...kind of similar to a burned valve.
WDZ
