Old 12-20-2009, 11:16 AM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Originally Posted by priobe View Post
As I looked closer at the rocker there is a c shaped indention in the rocker.
How can I measure the distance that is needed to check if I need to replace all the push rods.
Also, if I need to change the push rods what brand should I go with?
The push rods are smith brothers.
Or can I machine down the cup to allow clearance?
I don't know if the c-shaped impression from the edge of the pushrod cup is the culprit or not. As you have, I had thought of options of getting shorter pushrods, clearancing the rocker arms with a grinder, grinding the lips of the cups of the pushrods, changing to new rockers.
I feel your pain.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
