Old 12-21-2009, 07:46 AM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
With shaft and stand rocker set ups you need to adjust the stands to get the geometry to match your valve lengths and then get pushrods-----you use different length pushrods to set the geo on stud mounted rockers as the pivot point moves up and down with the pushrod length where as with the stand/shaft setups you need to move the pivot point by the stand height
