Did you miss the part where the OMB issued a correction and it will now do little to reduce the deficit?
No I didn't miss that, it's another example of Republican spin, sustained, altered and further twisted by the radical right. The OMB estimate, and granted it is only an estimate, was only SLIGHTLY reduced from it's original number. The projection is the deficit will STILL be substantially reduced.
SPO1715, if you don't believe the estimate it is likely you don't understand how the calculations were made. A more reasonable approach would be to question the math than to dismiss the calculations.
