Thread: Update on Build
Old 12-22-2009, 08:14 PM
T.L. T.L. is offline
Cobra Make, Engine: Harrison build #98 with Supercharged 6.2L of Chev Power, TKO600 5 speed gearbox
Originally Posted by Mando View Post
T.L. if your rear end is Commodore IRS suspension does that mean your car will have dish on the rear wheels? Bye the way I love those AP Brakes!
Regards.
Mando,
When looking around I went to Warwicks and saw the Factory Five type setup and saw a few benefits from doing the rear end from there. Warwick had done one to a Daytona so I grabbed the opportunity and ordered mine with their setup from Warwick.
It's a Lincoln Continental Mk8/Thunderbird SuperCoupe/..... rear that uses a Ford 8.8 IRS. The one I got had drums () so I had to source a few more items, but I am happy with what I am seeing progressing so far. The knuckles are similar to current Mustangs and I have put some Mustang hubs there with 5 @ 4.5" as the ones I had were 4.25". The rear brakes are also standard Mustang with the handbrake setup onto the caliper through the brake piston, and the axles are beefed up to handle a bit more grunt, even if I don't use it.
The wheel will be there with a deep dish, 4.65" backspace, so I should have a nice deep dish look on the car.
The AP Racing calipers were the first thing I purchased, and look mean. Only 4 pot, but I felt that that was enough stopping power for a car 1100kg's or thereabouts (1200 with me in it).
I have put a Torsen 2 lsd in the rear, as it was an open diff, and it has 3.27 for the gear ratio. I will keep it at this as it should mean 2200 for 100kmph.
At least 1/3 of the driveline is Ford!!!!!!!!!!!!, and it's the last part before the wheels
