Old 12-22-2009, 10:24 PM
PANAVIA's Avatar
PANAVIA PANAVIA is offline
The other test -- car on jack stands or a lift. wheels clear of floor and anything else.
Trans in "N" (netrual)
Clutch pedal to floor.
Start Car
Keep Clutch pedal down on floor
move lever towards first (slowly)
have someone observe for wheel movement
wheels should not rotate *AT ALL* all the way into 1st gear.
move lever back to neutral, then to 4th, up into N, then R.
again wheels SHOULD NOT MOVE AT ALL.
if they do -- the clutch is not disengaging all the way.
If they dont move, and you still have difficulty, the shifter (esp aftermarket) or shift forks are damaged.
Steve
