Old 12-23-2009, 05:51 AM
TUF-427's Avatar
TUF-427 TUF-427 is offline
Cobra Make, Engine: Drb,5.6 8tb Windsor,TFS heads,Dart Shp,TKO600 ,4link 9in diff.Ford acid rush Paint,convopro wheels.
Merv,
theirs a few of these mass flows kicking around Qld,
Mike Verner is running one also with great success.
You dont really need to buy the whole box and dice either if your already EEC4 injected,
It uses all the standard EEC4 Ecu,harness Distributor sensors etc which all can be reused,
Massflo is based around a Different Mass air Meter thats adapted to fit Above the Quad throttle body inside the filter,
this sensor is recalibrated to suit the ford Ecu Signal requirment for measuring the incoming air volume.
Alone prob wont make much more hp and will lose some low end torque over the Production long runner style intakes,
Combine it with alloy heads and a cam etc will wake the old girl up though..
And they look fantastic...
Chips and retuning only required once you want to increase the injector size,
which would be required if you did heads and cam etc..
Horsepower sells engines,Torque Breaks 9 inches...
