  #32 (permalink)
Old 12-23-2009, 01:27 PM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
Thanks SoTxButler,
Is anyone using these rockers. I am serioursly considering buying a set. I have called several pushrod companys to have them walk me through the setup pf the pushrod.
All, have said that they like to use 2 -3 threads at the bottom of the rocker. Some will take a wire and place it in the oil hole to see the direct spray of the oil to the cup.
After measuring and measureing there is only 1 adjustment that can be made with the Dove rockers side to side or pushrod.
The pushrod is the correct length and can not bottom out on the bottom of the rocker.
Rick,
I believe you are right. The Dove rockers can not hold the pressure that the the springs have.
I wouldlike to find out if anyone is using the Garrett rockers and have any complaints.
I have to admit, I am a little doubtful spending $900 with a company that is not popular and that does not answer their phone all the time. This is why I am reaching to you guys to see if anyone has used them before I make my purchase.
