Old 12-24-2009, 05:51 AM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
ok question.
Let me take this back to basic (at least for me).
RIck or any one else out there.
I put the Dove assembly back together after cleaning up the shafts and rockers. I placed the rockers assembly on the heads.
Question #1
When mounting the rocker arm assembly, with the adjustment screws all the way pulled back, should the stands be resting (flush) on the heads. Or should you have a .125 (1/8) inch gap on a couple of stands.
Question #2
If the camshaft lope is up, the pushrod is up, the adjustment screw fully lossen, should you have clearance on the rocker. Or is this normal.
