the answer to question #3 i put mine in the center of the left hand side axle tube....
question #2 your macnine shop will/should know how far to press on the bearing....
question#1 i put the bolt in from the inside and put a piece of tube over the bolt and ran a nonlock nut down on the bolt until it was seeted in the housing or you can use a stack of washers
