Old 12-27-2009, 09:57 PM
Michael C Henry Michael C Henry is offline
Cobra Make, Engine: Everett Morrision FE 427 so 2-4s
When I bought my car I also got all the plans and receipts. The builder designed a 25 gal tank with a forward facing sump so the under side profile slants up from the rear end to rear bumper. It has internal baffels, side fill tub to connect to flip top gas cap mechanism, and all that. It sits partially in the trunk and extends below. In his plans he kept referring to it as a water tank. A small tube close to the top runs from the front outer edge to the resessed center location where the fuel quantity gauge is located . that way the wire and sending unit are protected if you have the spare tire ridding on top of the tank.
Mike H
