Old 12-28-2009, 07:43 AM
jhv48 jhv48 is offline
Originally Posted by Calbullet View Post
Jim,
thanks for the info, just what I needed to know. Where is his new location at? Being in Sacramento, I would like to drive up and check the place out.
Mel
995 Greg St. Sparks, Nevada 89431.
And one little hint on how to put the washers and nuts on those bolts that your hands can't reach. Use an 18 inch extension on your ratchet and a shallow 13 mm socket. Then drop the nut into the end of the socket and put a few drops of silicone glue on the flat washer and lock washer and stick them to the top of the socket, above the nut. Then slide the extension through the side pipe opening of the body, along the sidepipe until you contact the bolt. Then, from under the car, reach one hand up to the bolt head and put your finger on it to hold it in place while you turn the extension slowly to begin the threading. Works on any that you can't reach easily.
Jim
