Old 12-28-2009, 06:36 PM
Got the Bug's Avatar
Got the Bug Got the Bug is offline
Originally Posted by Randy Rosenberg View Post
Mark, the BAR is no longer smogging to "year of block" - they used to do that until a year or two ago. Now they smog to "year of build" or SB100 only - those are your only two choices. Given that almost every Ford motor does not meet the current smog requirements when installed in an SPCN (ie: "year of build"), your only choice is SB100.
Good luck,
Randy...
Yep. SB100 or the new GM LS3 GreenRod motor is the only answer in CA.
If I was going to build a a new Hotrod in CA, I'd throw one of those LS3 motors in it in a second. SPCNS build, LS3 motor, easily smog every X years no problem.
Doug
