Old 12-29-2009, 06:31 AM
TUF-427's Avatar
TUF-427 TUF-427 is offline
Cobra Make, Engine: Drb,5.6 8tb Windsor,TFS heads,Dart Shp,TKO600 ,4link 9in diff.Ford acid rush Paint,convopro wheels.
Merv,
any crate motor still only gets you half the way there,
As their only really a long motor package for a windsor,
im not aware of a complete EFI style package,
maybe not from ford racing at least..
you still need to do the induction and fuel side on top of a crate engine anyways,
What you currently have now if yours is an 88-93 style mustang motor will be too small and restrictive for the 300-350 fwhp.
Intake,throttlebody,Maf,Injectors,Ecu Chip maybe even your current fuel pump all needs attention for that sort of power delivery..
If you want the Carby look,
You really cant go past the massflo intake setup with your choice of alloy heads and a mild cam you wont be dissapointed..
and all the benefits of a self tuning Mass air Management system...
Dont forget for the power this will make will require at least 24lb injectors and a chip..
Peter..
Horsepower sells engines,Torque Breaks 9 inches...
