Thread: Seat Heaters
Old 12-30-2009, 08:51 AM
Chilibit Chilibit is offline
Cobra Make, Engine: Superformance, Roush 402R, Kentucky Cobra Club
I use these with Kirkey aluminum drag buckets. I merely sliced the foam of the seat cover away from the material and inserted them. Then the heat produced is insulated from the aluminum heat sink by the foam. Toasty. Below 10 degrees F, you will start to wish for more unless you put the top on. Even then it is only an issue above 70 mph. I do suggest you put them on a relay to prevent accidentally leaving them on.
