Old 12-30-2009, 10:43 AM
psychoSEAL psychoSEAL is offline
Cobra Make, Engine: 351 Windsor
After a good conversation with Blas and your replies concerning my fan. I have come to the conclusion that this fan, while in the high speed is just to much to handle on my current system. The 40/50 amp relay and the 30 amp fuse is just not enough. After doing some research I found that a Taurus 3.8L fan can produce approx 4000 cfm while drawing around 45 amps. At the low speed a good 2500 cfm and 25 amps. So before I go out and change the entire fan/radiator/wiring I am going to replace the relay and the inline fuse while wiring to the low speed setting. This should be ample enough cfm to cool this motor. I'll keep you informed of my progress. Thanks!
