Old 12-30-2009, 06:17 PM
DonB DonB is offline
Cobra Make, Engine: CMC,Ford 302
Default CMC Cobra fuel pump &line mounting?
Is there anyone with a CMC or Street Beasts Cobra that has run their fuel lines and fuel pump? My engine builder suggested a Carter fuel pump and 1/2 in. feed and return lines with 3/8 in. from regulator to fuel log. Is it ok to run the lines up the frame along side of the trans and engine? I didn't want to run anything in that area for fear of drive-shaft failure. It doesn' look like there's much room on the outside of right center rail. I was also planning on running a trans cooler on the right side of the right center frame rail. Anyone have any pics of how you did it?
