Old 12-30-2009, 11:23 PM
fsiewert's Avatar
fsiewert fsiewert is offline
Cobra Make, Engine: Old ('93)CMC kit, SB ford
Default Trans cooler
I'm running a separate trans cooler in the oil cooler opening of the body. Ran the lines inside the Right frame rail and under the motor mount, under the alternator, inside the R upper control arm mount, and outside the radiator support bar, on top of the frame rail.
For the fuel line.......inside the trans tunnell on the Left sidewith the fuel pump forward so if the fuel line and drive shaft connect.....you suck air, not spray fuel.
