Old 01-01-2010, 08:08 AM
computerworks's Avatar
computerworks computerworks is offline
OK so riddle-me-this: Why does Mr. $314K 'restorer'/modifier use 5" worm clamps on both main frame rails and what lines are they holding?
I would think a 3/16" drilled hole and adel clamp riveted in place would not destroy the structure-and be lots more professional.
I don't think they are compression clamps; they look more like doubled-up soft-metal cable wraps, like original type. I know comp-style fuel lines were held in place with adel clamps, but were screwed to the frame with hex-head self-tappers.
I think that that style wraparound is correct, but I will have to go thru the archives to validate the wrapped clamps, though. I don't see that on many old shots...BUT I have seen orig frames with scratch marks in a circular fashion around the tubes, that might indicate that they once had a wrap-around clamp.
-And what are those wrinkles in the drivers side main rail?
I would guess bottom-out history scars or bad lift points. I know I wrinkled a frame section on my old GT350 on a bad day with a floor jack, way back when.
Don't see a return line leaving the Weber side. Anybody know?
This car got the webers in the 80's... let a weber expert address the fuel line config.
