Old 01-05-2010, 05:32 PM
patrickt patrickt is offline
Originally Posted by dlotz View Post
Does it matter what amp the alternator is or do the two (VR and ALT) need to be matched? I have received conflicting info. I have a 100 amp ALT and what appears to be the VR that was used for the 55amp alternators.
Yes, it matters. Voltage Regulators are limited by current just like any other electronic component is. That VR that I posted the pic on is solid state and will handle the 100amp Ford 1G Large Case alternator. There are Ford Voltage Regulators that are rated at a lower amp value than that, and maybe you have one -- I don't know. You can also buy a voltage regulator that will handle 200 amps, for about $25 bucks more. If you don't know the amp rating of your existing VR, I'd spring for the $26 piece that you know is rated for 100amps.
