Old 01-06-2010, 09:22 AM
Hray Hray is offline
Cobra Make, Engine: classic roadesters ltd, 302, T5
Mr. 13
We would like to think we are not way far off, the body is nearly perfect. While craig was spraying the last coat of primer I was looking in every direction possible while the primer was still wet looking for lows and highs. We think we are dialed in.
What to me is an unknown is doing the securing of the body to the frame and aligning the doors. However, with DV's method of cutting the cowl plates out and then aligning door that task may not be that difficult. So as long as the door fits the body good on all sides without doing major sanding and filling we are ok there.
The good thing is Craig is an expert on corvettes and working with fiberglass, and together we have done plenty of body and panel fitting.
I think the body should be going back on next week at the latest.
As for now gonna research steele rubber to find a little larger seal for around the roll bars.
Thanks for your comments and support. Ray
