Old 01-06-2010, 08:44 PM
Blittleton's Avatar
Blittleton Blittleton is offline
CC Member / Sponsor
El,
I have several setups for you to try. But why not a hyd. throw out bearing? It looks very tight on the engine side of your setup. It would simplify your set up and since you are changing transmissions. The lakewood bellhousing is very big in there as well, have you seen the Quick Time Bellhousings. These are the best I have used so far. If you go with a hyd throw bearing I would suggest a Tilton and a Tilton bearing adapter. Just my .02 worth.
Bill
Squeaky wheel always gets the grease!!
www.gcperf.com
